pointer to a 32 byte buffer
Dear all,
I need to initialize a dll parameter like this - a pointer to a 32 byte array.
Could somebody please tell how to configure that?
Mathan
Message 1 of 33
(7,263 Views)
Dears,
In the attached dll, am using scardstatusa function. In initializing its parameters, am struggling with the last two parameters. details
Message 2 of 33
(7,245 Views)
Attachment probs in last post.
Here look for details
Message 3 of 33
(7,242 Views)
Hi mathan,
what about wiring an U8 array with length of 32?
Message 4 of 33
(7,229 Views)
Hi Gerdw,
You mean like this????
Mathan
Message 5 of 33
(7,224 Views)
But if i did like what i have attached it comes up with the following error that i have attached and the application itself will get closed.(LabVIEW Crashes)
Mathan
Message 6 of 33
(7,217 Views)
Hi mathan,
IMHO you should also wire the *bATR input with a predefined array ("Init array" with U8 datatype and 32 elements length)...
You only supplied the length parameter, but no pointer to the buffer itself. You have to supply this buffer! The dll call will not create it on its own, hence the error message.
Message Edited by GerdW on 05-05-2008 10:20 AM
Message 7 of 33
(7,216 Views)
Dear GerdW,
I did like what you said, but it returns with the same error i have attached in my last post - "data buffer is too small for the returned data".
But this time there is no crash. How to proceed?
Mathan
Message 8 of 33
(7,204 Views)
Dear GerdW,
see what i have done. Is it correct?
Mathan
Message 9 of 33
(7,196 Views)
Hi mathan,
I would wire bPTRLen as input too - and I would make it an I32 (instead of U8) as the description speaks of "DWord"Smiley Wink
Message 10 of 33
(7,156 Views)
