point by point bandpass filter with bandpass frequencies slowly changing with time
I have a need to (ptBypt) band-pass filter a signal, but the band pass frequencies vary slowly with time, e.g., the band pass frequencies change linearly from 5-10 Hz to 10-20 Hz in 30 seconds. Can this be done?
Thanks.
Ian
(3,873 Views)
You could use the Ramp Pattern.vi for generating your friequencies for your filter and then use one of the PtByPt Filter VIs to do your bandpass filter inside of a FOR loop.  Should not be hard.
(3,864 Views)
Well, unless I initialize the filter, I cannot really alter the band pass frequencies. But if I initialize the filter, it resets everything.
(3,857 Views)
using "FIR Filter with I.C." seems to work, but I cannot find the byBypt version for FIR filter.
(3,852 Views)
If you look inside the FIR Filter PtByPt.vi you can see how it uses the IIR Filter with I.C. PtByPt.vi with an empty array of reverse coefficients.
(3,836 Views)
