plugin crash Remote Panel
I have a vi (LV8.0) in Windows 7, when i try to acces via browser it crashes (firefox 3.16, firefox 6, ie 8, chrome).
The plugin are installed, the runtime in installed ,
thanks in advance
Mauro.
(2,613 Views)
Hello Mauro!
First of all thank you for posting your question in this forum!
As you will see in the link below, there is a compatibility issue between Labview versions and different versions of Windows.
If you take a close look, you will see that there is is no compatibility between Labview 8 and Windows 7, so a good idea for start, would be to install Labview 2009 or 2010 in your system as soon as you work on Windows 7.
If you still experience same kind of problem after installing one of these Labview versions, I would be glad to help you from a different perspective this time.
Let me know if everything goes fine!
Cheers!
https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
Antonios
(2,596 Views)
