09-28-2009 12:19 AM
Hi
I doing a wireless project in which the data from the receiver is sent to a PC over serial port for plotting in real time.
On the transmitter side, there is an A/D converter that converts analog signal to 8 bit digital data. This 8 bit data is sent to the receiver for real time viewing.
I have build a simple VI that reads data from the serial port and plots them.
For example: If I connect a sine wave at the input terminals of the A/D converter, I should get a sine wave output in the VI. Unfortunately, I don't get that.
I am attaching my VI to this post. Please somebody take a look at it and tell me where is the mistake.
Thanks in advance...
09-28-2009 03:23 PM
Hello chaitu209,
Were you abe to confirm that the number of bytes is correct coming out of the serial port?
09-28-2009 03:39 PM
09-28-2009 09:57 PM
Sorry I have posted the same message in two different boards..
I receive a string of ascii characters from the serial port. Does lowering the baud rate controls the amount of data I receive?
09-29-2009 05:54 PM
im having a very similar problem..... can you share your vi in a version 8.6 or below?? here is my post
http://forums.ni.com/ni/board/message?board.id=140&thread.id=38434
