plotting on xy graph based on mouse coordinates
Posted wrong!
Message 11 of 15
(971 Views)
I do know this is just a practise code. But it still doesn't get close to what i needed. The above code, i can only see the mouse pointer on graph within the graph. Any mouse coordinates outside of the graph gets rejected and not shown.
If i on the Autoscale, the scale jumps crazily to a infinite number. Please help.
I will just let you know what i am accomplishing.
I am actually working on a final year project that detects the fall risk. My team has decided to use the graphical tablet to detect the movement of the patient attached with a buckle and a rod sticking out attached with a stylus at the other end of the pole. So my task now is to make as if my screen to be the XY Graph so wherever i move on the screen, the graph will show my movement on the screen with plotted lines
Message 12 of 15
(968 Views)
I know. Read the last paragraph of my first reply. If this is your schoolwork, you're the one expected to do it, even if the actual programming isn't the main point of your project.
___________________
Try to take over the world!
Message 13 of 15
(957 Views)
Thanks, i got it after trying out a different method. After much research.
Message 14 of 15
(954 Views)
Can you please share you code?
Message 15 of 15
(875 Views)
