plot scale property
Dear All!!
I'm trying to represent different plots in a graph and I would like to keep the different scales associated with each plot visible in this unique graph. Is this possible? Is there any special graph indicator? Do I need to choose a specific property using the property node vi. of the graph?
I'm looking forward to hearing from you soon,
Best Regards,
Miren
Message 1 of 9
(4,318 Views)
You can create as many scales as you want though readability might suffer. On the front panel, you can right click on a scale and select 'Duplicate Scale'. You then right click on the plot legend to assign a plot to a scale - i.e. "Y Scale>Amplitude 2".
Message 2 of 9
(4,308 Views)
Thank you very much for your answer. It was very helful for me.
Just another question: Is it possible to split a graph, so that each part of the graph contain a portion among all the plots?
Message 3 of 9
(4,300 Views)
Not sure what you mean exactly. Do you mean you want to take subsets of signals?
Message 4 of 9
(4,286 Views)
Hi again,
What I was trying to ask is how could I create different subareas in a single graph and place signals in those areas, as I wish. For example, if my original graph had 4 different signals in one unique area, what i would like to do is to represent 3 signals in a subarea and the 4rd one, in the second subarea.
Thank you very much in advance,
Miren
Message 5 of 9
(4,278 Views)
You could add a second graph, or use the MIxed signal graph type.
Ton
My LabVIEW Ideas
Message 6 of 9
(4,267 Views)
Ok! Thank you very much.
Just another question. Is there any possibility to duplicate the scale in a mixed graph type?
Message 7 of 9
(4,262 Views)
Hi Miren,
     You can right-click the Amplitude scale (Y Scale) and select "Duplicate Scale" as it is shown on the attached screenshot.
Hope it helps,
David Oña
Message 8 of 9
(4,238 Views)
Thank you very much for your answer. What I was trying to do is to duplicate the x scale, but I the mixed graph type does not give me that option.
Do you know why?
Message 9 of 9
(4,222 Views)
