plot scale association
is this possible:
I have a graph, it has multiple y-scales.... several on the left side of the graph and several on the right, I display only 2 at a time, it's basically a dual y-scale plot with selectable y-scales... I do this using property nodes and it works great.  I have drop down menus with different plots, and these plots will pop up on the graph when selected.... ok here's my problem/question
is there a way to associate a plot with more than one y-scale?
I need to associate plots with 2 y-scales, one on the left and one on the right side of my plots
reason is because it's basically a custom graph with 2 drop down menus, the drop down menus has groups of plots in it... each of the 2 drop down menus contains the smae plots and each is associated with either the right side y-scales or left side y-scales... this makes it possible for various different combinations of plot vs plot on the graph... but not being able to associate a plot with both sides limits me
right now I can do
plot1 vs plot2
plot3 vs plot4
but can't do
plot1 vs plot3.... because I can't associate plot3 with y-scales on both sides of the graph
I hope this makes sense,
much thanks!
(3,019 Views)
Accepted by topic author Monse
I'm not exactly sure what you're asking, but all of the statements below are true. Do they answer your question?
  1. A plot must always be linked to exactly one scale
  2. Many plots can be linked to one scale
  3. One plot cannot be linked to more than one scale
  4. A plot can be visible while it's scale is invisible
  5. A plot can be invisible while it's scale is visible
  6. You can always have extra scales that are not linked to any plots
(3,000 Views)
You're first point, "A plot must always be linked to exactly one scale" answer's it.... thanks.
(2,985 Views)
