plot one point with curves
Having a problem adding single data point to bundle of curves to be plotted.
Suggestions??
(2,999 Views)
Accepted by topic author markfranklin
Are you trying to add a fourth plot or add to an existing one? If you want a fouth plot, you need to have the data in the new cluster mathc the other clusters. That means making an array of each scalar. If you want to append this point to an exsiting plot, you need to use the Build Array function on one of the x and y arrays - before the Bundle.
(2,995 Views)
Thank you for reply.
I just want to add an independent point with a label.
Unrelated to curves plotted.
(2,987 Views)
Thank you, I did get this to appear to add the point since the scale changed in response.
However, I cannot see the actual point to format it's size, color and label.
Suggestions?
(2,975 Views)
Ah!  Found it!
(2,974 Views)
