plot of shared variable
Dear  All,
            can any one suggest how to plot the real time data and historical data on same graph using dsc module.i need continous real time data on graph but when i go into analysis mode i use offline data and real time data is disabled. i have a boolean control on;ly pressing that i want  to plot the historical data
thanks
(2,962 Views)
Preet, sorry you didn't get a reply back in June. If you still need help, please include a Snippet of your code, or attach your VIs, so that we can better assist you. It is a simple matter to plot two different sets of data on single graph, so if you have the code that you are working with, we can help you implement this.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(2,816 Views)
