plot length on x axis
In my application I am acquiring waveform data(amplitude and time) from my hardware for a certain duration and storing it in a binary file. At the end of it the user has to input length. Now I want to use this length as my x axis and plot the amplitude data I acquired earlier on y axis. For example, if the user enter length as 10, I want whatever amplitude data I acquired earlier to be plotted from length 0 to 10.
Message 1 of 10
(4,358 Views)
Hi
I have the following questions:
1. Is the 'length' information saved in the file, along with the waveform data?
2. Are you reading the from the file and then plotting on the graph or is the data plotted while being written into the file?
3. Is the length in units of time or samples? that is, if length is ten, does it mean 0 to 10 seconds of data or 0 to 10 samples of data?
4. what is the sampling rate for your data?
5. are you writing the waveform data type into the binary file or are you writing a 2D array of amplitude and time information?
6. Could you post your code so that we can understand the requirement better?
Regards
Freelance_LV
TestAutomation Consultant
Message 2 of 10
(4,348 Views)
 I am attaching a vi with this post.
The flow will be:
1. Acquisition of data for which I already have the attached vi.I am writing the voltage data and time data to a file in my acquisition program.
2. After the acquisition, 'length' information will be entered by the user in meters.
3. then comes evaluation. In evaluation mode, the program is supposed to plot a graph of length against voltage. For example, if the user has entered 10m, and the data acquired is for 30 mins, I want all the amplitudes for that 30 mins on y axis(which are stored in the file) against 0 to 10m on x axis and then store it in to another file.
i am also attachin the supporting vi's
Message 3 of 10
(4,325 Views)
and my sampling frequency is 100k. can anyone help?
Message 4 of 10
(4,309 Views)
Where are the other two VIs and the Ctl? ie Acquire, Process and MainDataCtl
Regards
Freelance_LV
Message 5 of 10
(4,275 Views)
Plot your data as a waveform that starts at 0 with an interval of length/(number points-1).
Message 6 of 10
(4,270 Views)
could you please send me a 2009 version compatible vi?
thanks
Message 7 of 10
(4,254 Views)
Message 8 of 10
(4,240 Views)
Thank you very much sir
Message 9 of 10
(4,236 Views)
I have this vi. I want to use x axis as my length.
I am attaching the vi as well as a sample file which I am reading in the vi.
Message 10 of 10
(4,214 Views)
