plot legend
i'm trying to combine several waveform graphs in Mixed Signal Graph. Then i realised that i couldn't see the individual graphs such as 'Wvfm 0->Plot 0' etc, i only see 'Plot 0'.
How do i achieve to get individual graph displays at Mixed Signal Graph? Did i do something wrong?
Thank you.
Using Labview 8.0
Message Edited by microes on 01-30-2008 12:56 AM
Message 1 of 10
(4,763 Views)
Hey Microes,
Thank you for contacting National Instruments.  I am having a hard time understanding what you are trying to do.  Is there anyway you could create a simple example VI that shows what you are trying to accomplish, and what results you are seeing?  I am having a hard time with just looking at the screenshots.
Also, the LabVIEW Help is always a great place to look as well if you not checked that out yet!
Kevin H
WSN/Wireless DAQ Product Support Engineer
Message 2 of 10
(4,703 Views)
i have several waveform signals which i want to be represent in 'Wvfm 0->Plot 0, Wvfm 1->Plot 0' etc (see attached 2.jpg) but when i wired in that manner, what i see at plot legend is 'Plot 0' (see attached 4.jpg).
I looked through Labview help on Mixed Signal Graph but i can't find anything helpful.
Is it something wrong with my coding?
regards
Message 3 of 10
(4,694 Views)
An image of a small section of code is not enough to really tell anything. How did you create the graph shown in 2.jpg? That looks like what would happen if you combined all three with a bundle and wire the result to the combined signal graph - exactly how you have it wired in 1.jpg.
Message 4 of 10
(4,671 Views)
Hello Dennis Knutson,
Shown in 1.jpg, i connected the XY graph to the bundle and mixed signal graph because i wanted to capture the screen shoot of my desired outcome for my program which is shown 2.jpg. But when i un-wire XY graph, i got result shown as 4.jpg instead. Couldn't the mixed signal graph display same elements in individual graph readings?
regards
Message 5 of 10
(4,663 Views)
No. When you bundle two arrays together, you've created an XY graph. If you want to show two separate plots, then you use the Build Array function. To show two separate plots, you don't even need the mixed signal graph. A regular graph will work the same.
Message 6 of 10
(4,657 Views)
maybe i'm not being specific in what i'm trying to achieve here. Forget about the XY Graph, my final program will consists of several waveform graphs which i wanted it to appear like 'Wvfm 0->Plot 0', 'Wvfm 1->Plot 0' etc and different signals represents by different colors at one plot area.
But somehow i couldn't get it right.
Message 7 of 10
(4,642 Views)
Hi microes,
did you have a look at the context help for a waveform graph? Did you read Dennis' messages carefully?
See example with 2 plots in one graph...
Message 8 of 10
(4,628 Views)
Hello GerdW,
thanks to your vi, i can understand much better. But i'm curious to know why couldn't i use the Mixed Signal Graph to see the same desired results.
Thank you.
Message 9 of 10
(4,615 Views)
Hi microes,
now with waveform AND mixed signal graph...
Message 10 of 10
(4,611 Views)
