plot legend disappear
here you go...
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 11 of 17
(1,339 Views)
Hi ssingh1,
I hope you have seen my vi. According to me if you place property node of Plot>>Colour in your vi and create indicator. The background color value corresponds to "Transparent " colour . And may be because of that all controls on FP were getting invisible.
Try my vi and give me feedback.
 Newaz it was nice post, took some time to figure out.I liked it.Smiley Wink
Best of luck
Message Edited by gak on 09-17-2009 01:33 AM
Gaurav k
CLD Certified !!!!!
Message 12 of 17
(1,339 Views)
Dear Gaurav,
I found that this problem was due to cursor. You can try it by deleting the cursor in orignal VI and then selecting the graph, all the controls become visibal. This seems to be a bug.
Someone at NI maybe can tell.
With regards
Shourya
Message 13 of 17
(1,328 Views)
HI shourya,
Yes I tried it and it works. But if you deselect the cursor you will not be able to use it. Don't you think it is adjustment with problem instead of solving it?Smiley Sad
That is what I think... Smiley Wink
Gaurav k
CLD Certified !!!!!
Message 14 of 17
(1,304 Views)
Accepted by topic author ssingh1
Use this. with cursor.Also controls will be visible.Smiley Happy
Gaurav k
CLD Certified !!!!!
Message 15 of 17
(1,300 Views)
If your problem is solved then you should mark solution.
Gaurav k
CLD Certified !!!!!
Message 16 of 17
(1,278 Views)
Dear Gaurav,
Thanks for your support.
I was busy with the project so could not reply earlier.
With regards
Shourya
Message 17 of 17
(1,258 Views)
