plot data following receiving from VISA
I am reading data from a microcontroller using VISA function in labview. I can convert these data to decimal values (this is what I want).
I want to build a X-Y graph in this way:
Every time I receive a value from VISA, I want to put this value on the graph (Y value) with respective number of reading (X value).
For ex. if the first time after reading VISA, I receive 128, I want to have X=1, Y=128 on my graph. If the second value from VISA is 154, I want to have X=2, Y=154, etc...
Could you please help me how to do that.
My main concern is how to build the X axis.
Thank you very much.
(2,666 Views)
You could build the X array the same way you build the Y array.  Keep the previous value of X in a shift register and add 1 every time you put an element in Y.
If X is always going to be the reading number, then you could use a waveform graph and just feed Y to it.  The only issue you would have is that the first element will have x = 0 rather than 1. The default condition for a graph is to use the index values of the Y array for the X-axis.
If you need the X-axis to start at 1, you have other possibilities.
1. Place a dummy element at location zero in the Y array. Turn off Autoscaling for the X axis. Set the X minimum value = 1.
2. Use Ramp Pattern.vi to generate the X array. (X-Y Graph).
3. Use a for loop and autoindex "i" to the X array. Add 1 to the array. (X-Y Graph).
Lynn
(2,629 Views)
