plot color issues
I am making a program that takes a reading from a DAQ board. My issue is I don't always want to see all the channels that we are using. So I want the ability to turn off the channels ( right now using a Boolean true false check box) and still see the other plots. I have gotten this far but when I want the colors for the plot line not to switch. For example plot 1 I had green and 2 red. When I unchecked 1 the 2nd line goes to green. I want it to stay red...Is this possible.
Thanks in advance
(2,874 Views)
Accepted by topic author Tech!
Hi Tech!
Try this.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,856 Views)
Had to just figure out how to implement it into my VI but once i got that it worked like a charm...
Thanks again!
(2,820 Views)
