plot area width changes as the precision changes !?
need help to understand following thing:
If I increase the precision of a graph manually, the plot area size decreases and vice versa.
Otherwise there is an example posted demonstrating prcision change by property node which does not change plot area size.
I've attached an example to demonstrate both.
What I want is to change the precision manually with the default graph tools without decrease or increase plot area width.
Is this possible in LV 6.02 ?
(2,683 Views)
Hi.
Resizing of the graph is the default behavior. The Graph resizes in LabVIEW 7 in both cases. I woud suggest building a text indicator with a transparent background and reading the properties of the graph to display the correct values to the side. This should give the desired response.
-Erik
(2,683 Views)
