please tell me how
please tell me a program that puts 0,0.01,0.02,0.03,0.04,,,,,,4in t in order.(ignore the v)
for loop couldn't because of integer.
(2,317 Views)
You could
  1. divide the for loop iteration i by 100.
  2. add a array with autoindexing as for loop input
  3. use a while loop and count yourself with add and shift register
there are sure more options, but those came quickly in my mind.
(2,302 Views)
Hi Hiddg,
Several options:
  • Use a FOR loop with 4/0.01+1 iterations. Let "i" autoindex at an output tunnel to get an array of integer values from 0…400. Then multiply that array by 0.01…
  • Use the Ramp function found in the Signal functions palette to generate your ramp values…
(2,297 Views)
This shows what others have described (except I chose to use primitives instead of the formula node).
(2,244 Views)
Why don't you look at the code I made for you three days ago??
(Unless you only have LabVIEW base, you should have ramp pattern.
You can do anything with integers including convert them to DBL. Just multiply [i] by 0.01, right?
You have now three different threads about the same problem. It would really help to keep it all in one place!
(2,233 Views)
