please help: the following equation is to be applied on the first column of values from the attached text file, then store the obatined values as a column in a text file,plot the obtained vaues
equation,
{ (mean value of [squares of first column values])- (square of mean of the first column values) } / { (square of the mean of the first column values) }
total number of column values is 46.
this equation is to be applied on the first column of the values in the text file AND PLOT THE FINAL VALUES THUS OBATINED IN A GRAPH.
Please help.
(2,438 Views)
LabVIEW has the functionality to do each step you have outlined. Do you have a more specific question related to LabVIEW?
(2,425 Views)
am new to labview..i donot know how to take the text file and extract only the first column values to perform the equation..please help me with a vi code to do it..:-(
(2,420 Views)
Well, since your text file fits the format of a three column spreadsheet with spaces as delimiters (hint), you might want to use the Read from Spreadsheet File.vi on the File I/O palette.
(2,416 Views)
