please help me to create .exe file for my VI.. thanks in million
Dear all,
The software I have is LV6.1 full version, so I cant make .exe file. 😞
Can someone help me to crate .exe file for the attach library thanks.
I need it for my presentation and the skol PC dont have LV.
if the file is big, pls send to maymaythar@yahoo.com.
thanks in million.
maymaythar
When you feel sad, laugh
(3,310 Views)
Hey,
Here you go fo rthe exe file...compiled in 7.1 so you will nedd the LV 7.1 run time engine on the target PC that can be downloaded here:
http://digital.ni.com/softlib.nsf/websearch/71b1d78c8dfba33786256e7d00724692?opendocument
Cyril Bouton
Active LabVIEW Developper
(3,307 Views)
Thanks for your help!
(3,293 Views)
What do you do when you are happy???
(3,282 Views)
I laugh 😄
(3,256 Views)
can you explain the steps in converting the vi to exe format? And can the exe convert back to vi?
Thanks alot
From
Donny
(3,194 Views)
As has been mentioned, you need LabVIEW professional or higher. (If you only have base or full, you need to buy the application builder extra).
Building an application is as easy as selecting "tools...built application or shared library", and specify the desired source VIs, built settings and installer settings.
All diagrams and unneeded front panels are removed. The process is thus irreversible and you cannot recreate the original VIs from the application.
(3,186 Views)
