pipe open error 6
I am using LabView Linux 2009. I want to use named pipes. I am unable to create a named pipe with mode = 1(write).
I am getting an error, however I do see the pipe being created.
Error 6 occurred at OpenPipe
Possible reason(s):
LabVIEW:  Generic file I/O error.
Thank  you.
-H
(5,018 Views)
Accepted by topic author H P
H P,
        If you search for Open Pipes Error 6 at ni.com, the third document is this KnowledgeBase (http://digital.ni.com/public.nsf/allkb/FB7A1B9D8C1A558186256CAA0083C290). It says that you must open a pipe in read mode first before you can open it in write mode. Do you think that this could be the cause of your error? What distribution of Linux are you using? Are you seeing any other error with LabVIEW in Linux?
(4,994 Views)
