picture ring odd behaviour
I'm having and odd issue working with picture rings, I populate the ring with the images i need of different sizes, knowing the sizes of the pictures I've created and array with width and height, then I size the ring using the indexed values af the array and the witdh and height property node of the picture ring, however sometimes the images are crop but the image ring has the right size, is there any explanation? Am i using the wrong property node?
(3,051 Views)
I don't know.
But if you attach your VI, we can look at it and figure out if you are using the wrong property node.
(3,030 Views)
The input reference is a Picture ring ref, the other controls are only numeric values, as you can see the bottom right Picture Ring is not in the right position
but al the Picture Rings comes from the same type def (I put it as stric so all the rings take the same appereance and then returned it to only type def )
(3,023 Views)
Hello jpao1990,
Could you share with us your entire project? If you only send us the VI, we have to create custom controls and a test VI, and we cannot see the entire picture of your project.
Best regards.
David P.
www.ni.com/soporte
(2,964 Views)
