picture indicator problem in LabVIEW 8.5
I'm reading a BMP image (size 3216x2136).  Trying to display it to a picture indicator ends up displaying a white (empty?) picture.  If I crop the image small enough (i.e., 3216x1500), it will display to a picture indicator okay.  However, if I try to convert the cropped 2nd picture indicator using "Picture to Pixmap", I end up with an image that contains only the background color.  If I reduce the cropping to even smaller (3216x1000), the Picture to Pixmap works fine.  Memory problems?  Or a problem in the picture indicator?  See attached VI and test image.
(3,448 Views)
Weird -- I'm not seeing the problem anymore.  Did 2 things:
1 - Changed the entry in my boot.ini file to remove the /3G flag (which supposedly increases the amount of memory LabVIEW can use?)
2 - rebooted my system
Hmmm.  Don't know if rebooting without the change to boot.ini would have fixed things.
(3,430 Views)
Hi mvickerman,
I'm glad that you were able to resolve your problem.  I'm under the impression that the computer reads the boot.ini file only when booted, so I believe that you would have to reboot the computer for the changes to take effect.
Cheers,
Marti C
NI Medical
(3,413 Views)
The LabVIEW Help actually explains the /3G flag. A copy of the page can be found here:
http://zone.ni.com/reference/en-XX/help/371361D-01/lvhowto/enable_lrg_ad_aware
Note that this only applies to 8.5 and above.
(3,399 Views)
