pic usb interface
hi, i am running a project. Now i need to interface my pic18 with labview. Can labview send or recieve command data to pic using usb. Please help!
(3,134 Views)
HI Xcoder,
I think before asking help take a chance to help yourself. Try to explore/search some discussion or KBs that can be help for your issue.
Please go through below mention discussions i think this can work for you as a solution
1. Communication Labwindows <--> microcontroller through USB port
2. PIC USB connection using Visa4.3.0
3. USB Instrument Control Tutorial
4. Communication between Labview and PIC
5. How can i use labview for communicating with pic18 microcontroller through usb port?
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,123 Views)
thank you very much. I am new with labview
(3,117 Views)
Dear XCoder,
Don't take it personally as you said you are new here with LabVIEW, so we are here for you to help out.
This only works when you already done some homework and still not getting solution but if you want us to do your homework this will never work for getting solution.
Thanks and Regards
(3,113 Views)
dear sir, actually i have finished a project in which my pic can communicate with pc and sends command to show a message . In pc side a vc++ app i use. Now i want to work with labview. Thanks for your kind help.
(3,104 Views)
