physical channel
hello,
i have a labview 7 and both IN-daq mx & traditional IN-daq. I take a vi from one of my friends. He wrote down the program 4 years ago and my labview can still open it. But in his program, the physical chanels are named as 0,1,2,..(like in attachment named "b") But in my lab we have sc-2345 so i have SCC1Mod2/aio,ai1 &scc1mod1/ai0,ai1.( total 4 channels)
my question is , how can i apply data using the same program? how can i convert his physical channell types (0,1,2..) into mine?
if we can do that, how can we connect it to the aiconfig.vi . I think the wire types does not match
thank you so much
batur
(2,605 Views)
If you have configured everything correctly in Measurment and Automation Explorer you should be able to right click and create constant on the AI Config. This will then give you an array of I/O constants which you will be able to select the configured information form MAX for each channel. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,605 Views)
