peak detector
Hi
I am using the peak detetor VI.
The detector algorithm is able to find the peaks in the data, but not the valleys.
How is that possible, or what settings should I use?
(4,028 Views)
hi PabloNL,
how about some try and error?
peaks: threshold = 2
valleys: threshold = 4
Alex
(3,997 Views)
btw the math behind is discret calculs
(3,988 Views)
Accepted by topic author PabloNL
Hi PabloNL,
What Alex means is that if you want to detect the valleys in your signal you will need a threshold that is defined as a higher value then your valley values. If you want to detect the peaks you will need a threshold which is a lower value then your peak values. Since you had a threshold value of 2 it works for your peaks but since the valleys are a higher value then your threshold they where not detected.
Rik Prins, CLA, CLED
Software Development Engineer
(3,959 Views)
While using this peak detection.vi how to find location in terms of time . They have given an equation in "help"  but I was not able to understand that perfectly.
@nk
(3,855 Views)
