peak detector
Well I will not give up!!!
And trying to use again the peak detector.
It is working but only i can see the results when hightlight execution, because when the program is runing in the normal mode I can't see nothing.
in the front panel.
I just want to see how much are the differents peak of the ECG signal!!! Is it so dificult?????
(3,294 Views)
It's best if you post some sample code with such a question. The usual case when you have different results in normal and highlight execution is that you have some kind of race condition.
Martin
(3,288 Views)
Another possibility is that there is more data available in highlight mode. If you are gathering points into an array, you will have many more available while highlighting. If this is the case, you can try adding some delay in your acquisition loop or perform more loops before you analyze.
(3,279 Views)
Here is a sample vi I did before to measure heart rate. Hope this helps.
Randall Pursley
(3,277 Views)
If you have stored data, take a look at this one.
Randall Pursley
(3,276 Views)
