pdfcreator invokes LabVIEW run-time engine installer!
Okay, so I'm a desktop tech, know little about LabView, but can at least install it.  We also use pdfcreator on our desktops.  For some reason, however, whenever pdfcreator is used (for ANYTHING, not just LabView stuff), a windows installer fires up, "please wait while windows configures NI LabVIEW Run-Time Engine 7.0."  The installer proceeds, then gets stuck while trying to find the msi.  Well I don't HAVE the proper MSI apparently, because my version is 7.1.1!  When I put in the 7.1.1 Run-Time CD (the only one I have) and point it to the msi it seems to be looking for, it still fails (apparently due to different versions).
So first, why is pdfcreator invoking this installer in the first place (they seem to have nothing to do with each other!)
Second, why is the installer looking for the Run-Time for 7.0, instead of 7.1.1?
Help!
Wiltony
(3,426 Views)
Well, I fixed it.  I eventually used the NI Software Add/Remove item, and chose "repair" for NI LabVIEW run-time 7.0, which called for the appropriate 7.1.1 device driver discs (strange).  After it completed, everything worked fine.
Wiltony
(3,413 Views)
