pdf saving error
hi, i want to save the data in the pdf file for that i downloaded the pdf generator toolkit
but it shows me error message and the pdf file becomes corrupted
please help me to sort out this problem,thanks.
(5,063 Views)
You are using a Third Party tool to create your PDFs.  As they say on their Web Site,
This product is supported by the third party and not by NI.
For technical support, contact Simplicity AI at:
Phone: +44 (0) 845 468 2886 or +1-877-717-1190
Email: info@simplicityai.com
Web: www.simplicityai.com/contact-us/
(5,012 Views)
is there any other method of saving labview data in pdf file from code itself
For example i have to save data in single pdf file from live running data or  it may contain many different sheets
i don't want to convert file  from any format that can be done easily with pdf itself
thanks,
ransher
(4,952 Views)
If it is related to your previous post, you could try to print to pdf if you have a pdf printer installed on your machine.
Ben64
(4,945 Views)
hi ben64,
yes, it is related to previous post the same information i want to save in pdf file.
How can i implement it in labview ?
Can you please suggest me which pdf printer i should download because their are lots of printers available online
(4,935 Views)
Accepted by wiebe@CARYA
I'm away from LabVIEW temporarily, but as I recall, Microsoft Word can save a PDF.  It is convoluted, but you could create a Report with the Report Generation Toolkit in Word, and could probably (with a Word Macro?) get Word to generate a PDF for you.  Alternatively, you could save the data in a nicely-formatted Text file (or HTML document or something that is "ready-to-print"), and (as ben64 suggested) use "something else" (Adobe Acrobat, perhaps?) to convert it to PDF.  You could do the conversion step "by hand" (i.e. let LabVIEW acquire and process the data and make a Text report, then exit and use Some Other Software to create the PDF) or you could use System Calls (I forget the proper name of the LabVIEW Function that basically issues DOS-like calls) to get the Some Other Software to process your file.
Or you could follow my suggestion and contact the people who made the PDF utility for LabVIEW that you are trying to use.
(4,914 Views)
yes i did that with  report generation toolkit
Thanks, for helping me cheers.
(4,877 Views)
