pda module - measurements_fetch missing vi c file
Hi -
I am getting an error that seems to be associated to the pulse measurements.vi.  Whenever I add it and its associated data to the block diagram, I get 4 errors:
measurements_clear is missing a vi or c file
measurements_fetch is missing a vi or c file
measurements_create is missing a vi or c file
measurements_destroy is missing a vi or c file
The pulse measurements.vi does have clustered inputs, and I have read this may be the source of a bug.  I did not however see the workaround posted.  Does anyone know how to resolve this?
(11,058 Views)
corey
What version of LabVIEW PDA are you running? Do you get this same error when placing the Pulse Measurements.vi on the block diagram of a VI targeted to your computer or just a PDA? Yo
u might try repairing your LabVIEW and PDA Module installs.
Xaq
(11,033 Views)
Xaq, Thanks for responding -
I have version 8.2 of pda and 8.20 of labview (student).  I didn't try a reinstall, so I will try that.
The VI does work however on a PC with no problems, only the PDA target gives me the compile error.  Otherwise the PDA projects compile and run correctly.
Thanks again
(11,029 Views)
Hi -
I am still having the same problem......
fresh install.....labview 8.2
I really need help, I have to get this working this week. Does anyone know of a bug with the pulse measurements vi for the pda module.
any help is greatly appreciated.
thanks
Corey
(10,445 Views)
Corey-
I tried building a PDA applications using Pulse Measurments.VI and got the same build time errors. I have filed a report with the R&D team to investigate and will keep you posted with any work around we find.
Xaq
(10,413 Views)
The VI contains function definitions that are currently not supported on PDA. Unfortunately there is no workaround. We will add those functions in the PDA analysis libraries in the next major release of LabVIEW.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(9,999 Views)
For reference, this was filed under CAR 48AEG1C5
Xaq
(9,980 Views)
