02-10-2006 04:21 AM
02-10-2006 09:10 AM
02-10-2006
11:03 AM
- last edited on
08-11-2026
03:12 PM
by
Content Cleaner
You might not need it, but I would recommend installing an emulator as well. Then even if you don't have the hardware, you can still do much of the development and testing. I know that this is handy when my Dell Axim is left connected to my home computer
Also NI has covered what you need in this link [link removed; article no longer available] as far as external tools. You will, of course need to be able to connect to your PDA to download to it and you will need a sync program for that (as mentioned previously).
Hope that this helps,
Bob Young
02-15-2006 12:24 AM
02-15-2006 06:23 AM
02-15-2006 09:48 AM
@ThSa wrote:
Have you installed several sw packages in the default folder? (especially those from MS)
In the meantime you can "Build" the PDA project on your host drive and save it via ActiveSync on the PDA device.
regards,
ThSa
02-15-2006 09:55 AM
Bob, I assume that was supposed to be hard drive. If you go to Tools>>Build for PDA instead of using the run button, the exe will be built in a directory on the HD of your choosing, normally the synchronized directory. If you do build to that directory, ActiveSync detects it after a second or so and updates the device with your new version. Even if the device is not registered with ActiveSync, you can often copy the exe to the Mobile Device folder to copy it to the PDA.
02-15-2006 10:22 AM - edited 02-15-2006 10:22 AM
Message Edited by ThSa on 02-15-2006 05:22 PM
02-15-2006 03:09 PM
02-28-2006 07:55 PM - edited 02-28-2006 07:55 PM
Message Edited by uclabme on 02-28-2006 08:04 PM
