pda cursor position property does not work
Hi!
I have a problem with cursor positionX propery on PDA.
I use PDA Module 8.2 and Windows Mobile 5 OS on PocketPC.
Actually problem is only when I try to get value of two cursors, it return the same value for both cursors (you can test it with attached VI), but when I set values it work fine.
I have also worked with PDA Module 8.0.1 in past and I remember that get cursor position value worked, so I have no idea why it doesn't work in newer version.
andrej
(4,209 Views)
Hello andrej,
Unfortunately I also see the same behavior on a PDA using this "active cursor" property. It appears to me that this property is not being written successfully. I say this because it appears that the value displayed is always from the most recently repositioned cursor rather than either the 0 or 1 which is set by the property node.
What I will do at this point is to file a corrective action request so that this behavior is corrected for a future release of the LabVIEW PDA module. I apologize for the inconvenience that this causes for your application. Please let me know if I can help at all as you modify your application to work around this behavior. Thanks,
Mike D.
(4,177 Views)
