pcie-8431/8, RS 485, Two wires mode not available
Hello all,
i hope you are doing well,
recently i bought a eight channels pcie-8431,  to establish communication with a product that handle half-duplex RS-485 protocol
i read that this model of pci is differencial but its possible to use the "two wire" method.
Would be helpfull if someone can give me a clue of how to do this, Thank you for your time.
Extra information: Im trying to change the setting though NIMAX --- Advanced settings, but that option is disabled (attached you will find an image)
(154 Views)
I forgot to mentioned that the PCIe-8431 has
TX+
TX-
RX+
RX-
And the product that im trying to connect has
D+
D-
Currently im connecting
TX+ with D+
RX- with D-
I don't know if this connection is correct
(143 Views)
See Set Up 2-Wire (Half-Duplex) Communication with RS-485 Port
Basically short Tx+ and Rx+ to D+, and Tx- and Rx- to D-
https://tmesystems.net/
(105 Views)
Thank you ZyOng,
i already did the test but i didnt receive the expected information.
In the post shared by you, mentions that its necessary to change the tranceiver mode from 4 wires to 2 wires mode.
but that option its not available in my NIMAX, do you know if i need extra drivers or any particular version of NIMAX?
Also, the PCIe- that im using is the 8431/8 and in the post mention only the following devices as compatible:
Hardware
  • RS-485
  • NI-9871
  • PXI-8431/4
  • PCIe-8431/4
  • PCI-8431/4
  • PCIe-8433/2
  • USB-485
  • PXI-8423/4
(89 Views)
Did you install NI-Serial and if you did which version?. Without that the board is at best available as a standard serial port if at all.
Rolf Kalbermatter  My Blog
(76 Views)
Hello Rolfk
Yes, the version of NI-Serial that i've istalled is 2025 Q4
And I'm currently using LV 2023 Q3
(55 Views)
