pci6602 counter problem
i was trying to program a counter on a PCI6602-board to generate a
delayed pulse.
the programm follows the example: config pulse with "start on rising
edge",
(trigger source is a digital out pin, because to counters must start
simultanously)
then "start counter" and finally output a "TTL-high" on the digital-out
pin, which is
connected to the counters gate.
when measuring the pulse with an oscilloscope, i noticed that the first
pulse after
starting up labview is omitted (nothing happens, although the programm
runs without
any errors), the following pulses are ok. When i restart the program
everything is fine,
even the first pulse. Closing Labview makes the counter omitting the
first pulse again.....
Does anybody know why this
happens ?
I programmed a workaround by generating a very short pulse the following
circuit can't follow
on programm start-up to avoid this behaviour, but i'd like to understand
this "phenomenon",
which had cost me two whole days to discover. 😉
Regards
Stefan 😉
|| Stefan Tauche Infineon Technologies AG, Munich
|| A Siemens AG Company
|| Email: stefan.tauche@No-spam.infineon.com
\\=========(remove No-Spam from address to reply)==========
Message 1 of 1
(3,041 Views)
