pc/sc Scardtransmit
hi,
I have a problem to interface pc/sc smartcard reader using pc/sc with the windscard.dll. The function ScardTransmit sends me an error message wrong parameter.
LONG SCardTransmit(
__in SCARDHANDLE hCard,
__in LPCSCARD_IO_REQUEST pioSendPci,
__in LPCBYTE pbSendBuffer,
__in DWORD cbSendLength,
__inout LPSCARD_IO_REQUEST pioRecvPci,
__out LPBYTE pbRecvBuffer,
__inout LPDWORD pcbRecvLength
 more detail in http://msdn.microsoft.com/en-us/library/aa379804.aspx. I don't try to pass a correct format for the 2 parameters. I have seen an old post about it, but without the final solution.
typedef struct _SCARD_IO_REQUEST{
    DWORD dwProtocol;   // Protocol identifier
    DWORD cbPciLength;  // Protocol Control Information Length
} SCARD_IO_REQUEST, *PSCARD_IO_REQUEST, *LPSCARD_IO_REQUEST;
 Can you help me, please.
emmanuel
Message 1 of 59
(10,704 Views)
Dear Emmanuel,
Hope you are fine.
I think you are mentioning about the post i involved in the discussion here.
What you have done till now? Post your work. That will help sorting out the problems easily. I think i might help you.
Mathan
Message 2 of 59
(10,681 Views)
thank you for your rapidity,
So for the moment, i have the ScardListReadersA, the Scardestablishcontext,  Scardconnect and ScardStatus ok ( i have the ATR of my smartcard). But now, i don't understand how to  formate the input of the ScardTransmit ( i have the response wrong parameter 0x80100004).
I have seen your post, but i can't open the VI, because of my labview version.  So could you please send me pictue of your VI, and specially the structure of LPCSCARD_I0_REQUEST, and the different input using in the ScardTransmit.
thanks,
manu
Message 3 of 59
(10,671 Views)
Hi Elmanou and Mathan,
I happen to find your post here, and realise that you guys were discussing the same issue that I am currently facing. Let me briefly explain what I had done so far. I manage to get the response from the smart card reader, same here, I stuck at the point on how to formate the input for SCarddTransmit. Please help, If possible please send me the vi or the print  screen which would be really helpful. I am reacable thru eitys@hotmail.com
 . Thank you so much
Best Regards,
Shien Eit.
Message 4 of 59
(10,266 Views)
Hai all,
I did managed to made it work. But give me some hours. I need to search in my PC for the file and attach here in another 4 to 5 hours (that is at lunch time). Sorry for the delay.
Mathan
Message 5 of 59
(10,251 Views)
Thanks Mathan,
Looking forward to your reply.
Best Regards,
Eit
Message 6 of 59
(10,248 Views)
Hai,
Am very sorry for the late reply. Unable to locate the file. I can do onething. I don't want to start again since i have no readers or cards to check with. So can you please post the vi you did as of now so that i can help you from there. I am sure we can sort out this.
Mathan
Message 7 of 59
(10,225 Views)
Hi Mathan,
Attached is my VI,a read text sub-VI. With these VIs, I am able to get a ATR reply from the card reader. However, I have problem in formulate a correct input to the "SCardTransmit' CLN. There is always a error "6" return.
The commands to be input are as follow,
1.
0x00
0xA4
0x04
0x00
0x00
2.
0x80
0xCA
0x9F
0x7F
0x2D
Kindly, give me a solution, many thanks.
Best Regards,
Eit
Message 8 of 59
(10,217 Views)
Hai Eit,
I have downloaded your vi's. Let me give me some time. Ill have a look at it and post before this evening.
Message 9 of 59
(10,213 Views)
Hi Mathan,
How was my program, do you have any clue why the scardtransmit is not working? Hope to hear from you, thanks.
Eit.
Message 10 of 59
(10,185 Views)
