parent child vi - bugs
Thank you very much...!
Balaji DP
Message 11 of 17
(919 Views)
Hello Nitzy,
                       if i did =0, the case structure nothing will do...  as per my task if i press on the graph it should be move any place with in the main.vi....
if there is any Labview experts solve my issue.... please..
Balaji DP
Message 12 of 17
(914 Views)
Hello Nitzy,
Balaji DP
Message 13 of 17
(914 Views)
@Balaji DP wrote:
Hello Nitzy,
I'm not sure I understand what you are asking. Are you saying you want to be able to move the child window around inside the parent window?
Message 14 of 17
(901 Views)
yes, exactly same.... i want to move the child window within the parent main window....
Balaji DP
Message 15 of 17
(886 Views)
i am waiting for the solution.... i challenged to my team, everything possible with the labview software... only for this issue i am struggling to complete my application software. lets go through this example i want to sent a child vi with in the parent vi, and it should not move out from parent vi. and if i use mouse down event on the child vi the vi should not come down...
actual requirements of my task is, i have a parent vi and child vi (i.e graph) i can move this vi to any where with in the parent vi. and the child has a invisible title bar, using mouse down event on the graph this vi can able to move to any where with out windows title bar, for that i am using "positionFPopenmousedown.vi" this vi read the current position of window. and if i press the mouse button on the child vi, the vi should not come down
Balaji DP
Message 16 of 17
(870 Views)
if there is no solution from ni - labview software.................
i have to loose my labview software then have shift in to the microsoft visual studio....?
sorry for disturbing you.....
Balaji DP
Message 17 of 17
(845 Views)
