parametric estimation mimo
I'm using a VI from Parametric Model Estimation - SI estimate Orders of System Model VI. I see that it can be used in SISO, partially in MISO and limited in MIMO. Is there any way I can implement the estimation for MIMO?
Andrea
(2,866 Views)
Hi AndreaD,
If you look in the example finder there is a MIMO State-Space Model Estimation (DAQmx).vi that you can use to see how a MIMO input would look like.  The VI used is a different VI, but it still uses the waveform stimulus and response signals in the same manner.  I would also check out the help file on that VI.  At the bottom of the document it will direct you to GlassTube.vi which uses the VI you're describing.
Bobby Breyer
(2,837 Views)
Hi Bobby,
Thank you for the response. Is there a way I can implement MIMO models by using a bunch of MISO functions?
Andrea
(2,800 Views)
Hi AndreaD,
I'm unsure, maybe you can tell me a little about your application and so I can fully understand what you're asking?
Bobby Breyer
(2,787 Views)
