parallel
Which driver can I use to send commands to the parallel port? I can't find
it anywhere. I've heard that VISA can be used, but what is the learning
curve on that? I just need to send commands to the LPT1 port. Thanks!!!
Charley
(5,106 Views)
Hallo, charles,
Du meintest am 08.03.00 zum Thema parallel:
No driver, but a *.vi.
Do you want to control a printer, or do you want to control the lines of
the printer port?
The latter goal you can reach with the "port-IO"-vi, should be in
"memory".
Viele Gruesse!
Helmut
(5,105 Views)
Hi Charles
You will find that ASRL::10 is LPT1.
Tim
> Charley
(5,105 Views)
The other responses mention several important steps, but don't mention that
as far as LV is concerned, the parallel ports are treated the same as serial
I/O. Use the serial VIs to control the port.
Greg McKaskle
(5,105 Views)
In article <38C99D58.3CA2B2DF@austin.rr.com>,
can't find
learning
Thanks!!!
that
serial
> Greg McKaskle
I am trying to accomplish the same parallel port communication. I tried
to use the serial I/O vi's but it keeps giving me an error message if I
try to use anything but the COM ports. I tried to read from serial with
the po
rt=10(should be LPT1), I received the same error on two different
computers. It doesn't seem to be able to find LPT1.
Mike
Sent via Deja.com http://www.deja.com/
Before you buy.
(5,106 Views)
> the port=10(should be LPT1), I received the same error on two different
> Mike
> Before you buy.
I believe that you must have an entry in the labview.ini file
that states what ports you are using. (Win 9x and NT)
For the parallel port you should have an entry called
labview.serialDevices="com1; com2; ..... \\.\com10"
Check the help file to make
certain this string is correct.
Kevin Kent
(5,105 Views)
> > Mike
> > Before you buy.
> labv
> Check the help file to make certain this string is correct.
> Kevin Kent
> Kevin.Kent.vcf Type: VCard (text/x-vcard)
> Encoding: 7bit
> Description: Card for Kevin B. Kent
BTW,
Does anybody managed to control Parallel port vith VISA. Is it even
possible and where is an example? ASRL10::INSTR is very good, but how to
control communication?
Sergey Krasnishov
____________________________________
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
(5,105 Views)
