parallel while loops
@LKcire wrote:
Thanks, it wouldn't let me drag and drop because I have an earlier version of LabView.  Would you be able to just post the .vi so I can work with that?
If you have an "earlier version", you need to tell us what version that is. Else a VI will no help you either unless we guess right. (Seems to be 2016 from your first post.)  Also note the correct letter case of the word LabVIEW.
Message 11 of 15
(1,541 Views)
Yes, sorry I am using version 2016.
Message 12 of 15
(1,532 Views)
Well there's your problem...
You need to use Queues, Notifiers, or Channel Wires to pass data between While Loops.
In your case I suggest you study the Producer/Consumer architecture, as that's pretty much what you are trying to do from the looks of it.
=== Engineer Ambiguously ===
Message 13 of 15
(1,516 Views)
Any chance you could send me a 2016 compatible VI so I can see exactly what you did here?
Thank you agian.
Message 14 of 15
(1,497 Views)
Here is the vi posted by Sebastian.Weber saved for LabVIEW 2016.
Paolo
Message 15 of 15
(1,475 Views)
