parallel port voltmeter -convert C source code in to labview
G"day.
I'm trying to build a mulitimeter which can conncet to
a PC through the parallel port.(LPT 1)
I have written a simple circuit using C .( 16 bit dos application
which has difficulties in running in windows XP)
I want to get a decent user interface which supports windows XP.
I have very limited knowledge in LAb view.
IF annyone could help me to convert my c porgram that would be great.
pls find the attached 1. c program (source code + exe file)
2. circuit description..
thanks,
ryan
Message Edited by rsd3k on 10-13-2006 12:01 AM
(3,242 Views)
Ryan,
If you are not familiar with LabVIEW I would reccommend downloading the "Learn LabVIEW in 6 Hours" course from our website.  It's free and gives a great introduction to LabVIEW.  Here's a link.
I would also look at the VISA examples in the example finder (Help->Find Examples) because VISA is the driver that gives you access to your parallel port.
I hope this helps,
Justin D
(3,214 Views)
