parallel port / NT 4.0 / Labview 5.0
How can I control the parallel port i/o pins with labview 5.0 and NT 4.0 ?
The sub.vi "out.port" doesn't work.
Thanks for any advice
Andreas
(3,271 Views)
Hallo, Andreas,
Du meintest am 03.11.99 zum Thema parallel port / NT 4.0 / Labview 5.0:
> NT 4.0 ? The sub.vi "out.port" doesn't work.
You need the file "hwaccess.*" from the NI ftp server.
Viele Gruesse!
Helmut
(3,271 Views)
I use a DLL that was written in CVI to control the parallel port. CVI
drivers for Inport and out port will work under windows NT. This is not a
fast solution but it does work.
Also a long time ago (In a galaxy far far away) there was a canned Import
and outport DLL that worked with LabVIEW under Windows NT on Nationals
Instruments web site. If you cannot find it, I could email you the dll I
wrote but it is designed to work with EPP printer ports.
From John Harmon
Web Page: www.bright.net\~harmonj
Email: harmonj@bright.net
Land Line: 330-848-0460
Pager: 330-490-0091
Andreas Balzer wrote in message
news:38206be2@guardhouse.chbs...
nd NT 4.0 ?
> Andreas
(3,271 Views)
Not so long ago, not so far away:
http://digital.ni.com/public.nsf/websearch/c80752c53094c296862565f3007ac765
(or search the NI KnowledgeBase for "parallel and pins")
--John Lum
(3,271 Views)
You should be able to use the VISA functions, with the parallel port
appearing as a serial port with an address greater than 10 (emphasis on
*should*). The VISA functions are great for serial communications although
they force you to do a little more programming.
VISA:
"Andreas Balzer" wrote in message
> Andreas
(3,271 Views)
