parallel for-lopp configuration not possible
@Yamaeda wrote:
Why wouldn't you just use 64 all the time (can the default be changed?) if it's the lowest of threads and this number ...
Well, each generated parallel instance is a code duplication, so it is also a matter of memory use. There is typically a sweet spot that gives you a good balance.
Message 11 of 11
(298 Views)
