parallel data acquisition from multiple HP34970A meters
All,
I have a subroutine which scans through about 120 channels recording voltages and dumping them in an array. I use MEAS:VOLT:DC? command and supply it with a scan list.
To do this I use 2 34970A meters each with 3 20-channel 34901A cards. What I have observed is that the data collection is serial - the subroutine goes through 60 channels on the 1st meter and then goes to the 60 channels on the 2nd meter. I am using a 82357A USB/GPIB Interface for all my data collection.
My questions is there a way to collect the data from both the meters simultaneously to save the time?
The reason being I am trying to scale this subroutine from 2 meter to 11 meters and it would certainly help me if the data acquisition from all the meters is done at the same time.
Thanks in advance.
(2,933 Views)
You can't retrieve data from the instruments in parallel (unless you have 2 GPIB boards) but you can certainly tell both of them to start acquiring at the same time. I don't have the manual or driver handy but you are going to have to change how you are doing things. Instead of doing a MEAS?, you will need to set both instruments up for a software trigger or use an initiate command. Provide the scan list and then send the software trigger/initiate. If my memory is correct, you can poll each to see if the scan is complete and then do a fetch of each.
(2,929 Views)
Here is what I am trying to do. But I get following two execution errors on the 34970A:
-420 : Query Unterminated
-113 : Undefined Header
Since the vi was long I am splitting the prtscrn into 2 parts:
Part 1:
Part 2:
Since I have never used the INIT, TRG, FETC commands I think am making mistakes in writing these commands to the instrument. Any help is appreciated.
Thanks.
(2,899 Views)
You are making a mistake with the very first command. You are doing a CONF:VOLT AC? or VOLT:CONF:DC? Anytime you put a ? at the end, that's a query (your are requesting data from the instrument). You then issue another write without doing a read so the query is terminated. As I mentioned, I don't have access to the manual right now so look up in the manual for the proper syntax of configuring a scan list. It may be as simple as removing the '?'.
(2,896 Views)
