padding a string with spaces
How do you pad a string w spaces using "Format into a string" w/o typing /s/s/s/s/s for say 5 spaces ?
(6,415 Views)
Accepted by topic author Clint1000
Hi Clint,
this way:
(6,395 Views)
If you need PASS to be left justified with the spaces after, then the format string would be %-8s
(6,378 Views)
what about between the Lower limit and upper limit and the upper limit and test value??  Do I put a empty string on the format into a string then use the %5s??
(6,375 Views)
Yes
(6,371 Views)
nice...thanks..
(6,357 Views)
You really should mark Gerd's message #2 as the solution and not mine.  He presented the idea of how to do it.  All I did was answer a couple followup questions you had.
(6,345 Views)
