output of 9421 sinking digital input toggles
I have a 9421 Digital Input module.  I am only using one port (0).  The line is "high" all the time.  I can see this on the LEDs and on the MAX tool.  I can toggle the line and see the LED and MAX change, so I know I have the thing wired correctly.  But under normal operation, it is always ON.
Problem is, when I run LabVIEW in trace mode with a probe on the DAQ ExpressVI output, I can see that every other time my code cycles, the output flips from TRUE to FALSE and back again... and so on.  The DAQ ExpressVI is inside a while loop.
Any thoughts?
DH
(2,740 Views)
Accepted by topic author Dark Hollow
I had the "Simulated" cDAQ selected Smiley Surprised
DH
(2,716 Views)
