output array index from comparing input value to array value
i am trying to get an array index value by comparing an input value to the values in the array.  the closest value in the array to the input would result in the output being the index of the array.
for example
array value        index
0                            0
7                            1
15                          2
30                          3
If my input was number 17, then i would want the output index to 2.   i attached a vi with the  array , input, and output blocks, but i can't figure out how to efficiently solve this.
thank you
(3,133 Views)
Hi Ifoitek,
      Rounding the result of "Threshold 1D Array" (see Array pallet ) should do it!
Cheers
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,128 Views)
(The function "threshold array" only works for the very special case of an array sorted in non-descending order. So, depending on your array, it may, or may not give the correct result :().
In the general case, just take the absolute difference between [array] and [input], then get the index of the array minimum 🙂 . See attached (LabVIEW 8.0).
(Of course of you have multiple elements that are equally close, finding all might need a bit more code. 😉 The above finds only the one with the lowest index).
Message Edited by altenbach on 01-13-2007 04:17 PM
(3,125 Views)
You're right (of course Smiley Wink ).  I shouldn't have assumed Ifoitek's data would always be in ascending order, just because his example was.  When you're on the field and catch these slips, it reminds/motivates one to work harder - not to let them slip by.
Cheers. Smiley Happy
Message Edited by tbd on 01-13-2007 07:21 PM
(3,113 Views)
