oscillscope project
How was the oscilloscope project working while you were away?
Hope your trip was good.
Desole' de lire que plusieurs personnes que tu connais sont decede'es..
Tout va bien... Merci.
R
Message 391 of 401
(1,417 Views)
Merci bien Ray 🙂
C est la vie , tse quoi faire !!!!
en tout cas , je vais mettre bientot la derniere version du project Osc qu'on a fait.
On etait entrain de travailler sur le fichier .xls (the header ) remember ?
A bientot
LV 8.2
Message 392 of 401
(1,401 Views)
So AS I told you before , The strings are all fixed length. The lengths should be defined in the structures provided. I will Attach the file again since it is in previous threads ,Things like title and labels must be defined by the user.
We could have defaults. (we have the date in the title now so taht's good) The title could be the current date and time.
Later on :
The trigger can be complex. Usually the user selects a channel, a voltage and whether the signal crosses positively or negatively.
You should also be able to trigger on a keypress.
LV 8.2
Message 393 of 401
(1,388 Views)
Here is the structure that will read our .bin file back in his software. basicaly it is ExportBPB file.
Public Type BioProc2_settings
    title As String * 100
    numChannels As Integer
    ndata As Long
    rate As Double
    duration As Double
    loaded(0 To 64) As Boolean
    channelNumber(0 To 64) As Integer
    freq(0 To 64) As Double
    gain(0 To 64) As Double
    offset(0 To 64) As Double
    graph(0 To 64) As Integer
    colour(0 To 64) As Integer
    label(0 To 64) As String * 10
    units(0 To 64) As String * 10
End Type
Global BioProc2file As BioProc2_settings
For the “title” use the following: “BioProc2 binary file. Version 3.00. “ then add your date information.
The title must be 100 characters long. (i.e., string * 100).
do we have enough information ?
Message Edited by kmous on 11-05-2008 09:56 AM
LV 8.2
Message 394 of 401
(1,387 Views)
And i am still refreshing the memoryyyyyyyyyyyy 🙂
LV 8.2
Message 395 of 401
(1,383 Views)
Hi kmous,
wow.. that's a lot of items..  Maybe we should start a new thread based on each diiferent topic group.  One thread for the xls (header?)  another for the trigger, etc.
Otherwise, this long thread becomes confusing, even for myself.  😉
R
Message 396 of 401
(1,376 Views)
Ok Fine I will make a new thread for the Xls header file.
LV 8.2
Message 397 of 401
(1,363 Views)
Thanks..
That way, if someone else is looking for a similar solution it will be easier to find...  and others might be able to help also as I have become overwelmingly busy.
R
Message 398 of 401
(1,343 Views)
I am new user and wantI am new user and want to learn LAbview. I have to develop Digital Oscilloscope but I have no clue how to design it. The project is based on collecting vibration signals from the field and analyze it on the digital oscilloscope. to learn LAbview. I have to develop Digital Oscilloscope but I have no clue how to design it. The project is based on collecting vibration signals from the field and analyze it on the digital oscilloscope.
Message 399 of 401
(859 Views)
Message 400 of 401
(859 Views)
