oscilloscope's interfaces
I am on duty in a project and i should investigate oscilloscope's interfaces and how their parameters are adjusted in labview. However, i am beginner in labview and i can't find any information  about how i will access to the interface in photo. To access it in labview, are there any program that i must download?
(2,952 Views)
There is no interface shown in the picture.
There are several common types of remote programming interfaces - RS-232, GPIB, Ethernet, and USB. For all three, you need to install NI-VISA. This is driver that comes with your LabVIEW distribution or you can download it. For all, you would need the correct type of cable and a correct port on your pc.
For this particular instrument, there is an instrument driver for it. It supports GPIB, serial, and USB connections. From here, you will find links that explain what an instrument driver is and how to use one.
Finally, you will want to start with the LabVIEW tutorial before trying instrument control.
(2,944 Views)
I would try searching for your model oscilloscope in the Instrument Driver Network.
(2,942 Views)
