oscilloscope blocked
@the_ghost wrote:
should i use a trigger edge  like this ??,how  i can  configure it
Use that one. Set your edge to rising, 0.1 volt level.
Message 11 of 29
(1,363 Views)
Please don't post bitmap images to the forum.  They take up way too much space.  You may have think you called it a jpeg to get around the forum ban on .bmp images, but it is still a bloated bitmap image at its heart.
Use .png as your file extension.  It is generally 1/10th the size of a bitmap, and replicates the images well.  Real jpegs are usually a bit larger larger than .png's, and will show compression artifacts on images like you posted that are basically computer screenshots.  Jpeg's work better for photographs where you can't see the compression artifacts.
Message 12 of 29
(1,353 Views)
Guess you really didn't know how to use an O-scope...
Bill
CLD
(Mid-Level minion.)
Message 13 of 29
(1,340 Views)
<rant on>
It's also hard to believe someone actually thinks that changing a file name is going to change the contents of the file. I just think it's a cheat to get around the bmp ban. Do these people really think we're so stupid as to not notice?
<rant off>
Message 14 of 29
(1,331 Views)
@the_ghost wrote:
when i make 1 v(sinuzoidale) the program read the signal correctly but when i make (30mv)my program is blocked(does not respond)
That sounds like the trigger level is default so something like 50mV.  If you are dealing with true AC simusoids (goes positive and negative), then I recommend setting the trigger level to 0V.
Message 15 of 29
(1,321 Views)
@Dennis_Knutson wrote:
<rant on>
<rant off>
What do you mean I can't rename my .docx file to .pdf?  Had this conversation multiple times.
Message 16 of 29
(1,300 Views)
the probleme is not solved by the trigger edge and the scope is blocked and the trigger icon will flashes in the screen of the oscilloscope
i was chhanged the value of trigger level for many value(0,0.00001,1,.........) but the problem is the same
thank you very much 🙂
Message 17 of 29
(1,281 Views)
Hi ghost,
don't you understand what all the other people try to say you about that BMP vs. PNG thing?
Your picture reattached as PNG takes just <2% of the filesize...
Good advice: you should change your regional settings to use the point as decimal separator when dealing with external measurement devices!
Message 18 of 29
(1,260 Views)
Exactly what signals are you capturing on the oscilloscope?  What type of signals?  What amplitude?  What offset?
Message 19 of 29
(1,251 Views)
i was sinuzoidale waveform ,offset=0and the mplitude between 1.5v and 7mv  ,
Message 20 of 29
(1,243 Views)
