orthogonal variable spreading factor
iam new to labview can anyone help me in building orthogonal variable spreading factor in labview.
(1,452 Views)
What kind of help do you need?  I recommend you post more information on the need.  Forums can be helpful but with little guidance you will not get too far.
ALE Consultants
(1,315 Views)
LabVIEW is just a programming language. Can we assume you have all the theory and formulas ready and fully understand the math?
In that case, all that's left is implementing it. There are learning resources listed at the top of the forum, so star there. Once you have a draft and get stuck, come back, post your code, and explain what you have problems with.
What hardware do you have? Note that there is a specialized forum for software defined radio discussions. That might be a better place.
(1,306 Views)
