optimization nested loops for speed
Hi Bob, could you save that as a 2014 or lower VI? Now I'm curious!
Message 11 of 20
(4,100 Views)
Gregory,
     Sorry, I was running errands.  I'm going to post this as a 2014 Snippet -- it's short and simple enough, and illustrates the points.  Note that I use the High Resolution Timer (the stop watch) which is one of the NI "Hidden Gems" that is available through the LabVIEW Tools Network.
Message 12 of 20
(4,072 Views)
Same but with the high Perfromance library, which is now free.
Cheers,
mcduff
Message 13 of 20
(4,058 Views)
"the high Perfromance library, which is now free."  Except that it is for Windows only.
Lynn
Message 14 of 20
(4,045 Views)
Sorry. I too use a mac for everything, except for LabVIEW.
Cheers,
mcduff
Message 15 of 20
(4,039 Views)
Thank you Bob, the matrix method is indeed quite fast, taking only about 15ms on my machine. I'm a little confused now because johnsold's array method took 135ms while yours took about 950ms, and they seem identical. Even moving the "transpose 2D array" outside of the sequence structure on yours does not cut the execution time down. I've disabled debugging on both on them, I just can't think of what else might be different...
Message 16 of 20
(4,028 Views)
Note that the matrix and explicit versions are only equivalent if the input only contains positive values. If you would subtract 0.5 from your random numbers, the results are only equivalent if you add an absolute value function after the matrix operations. (Seems to be pretty cheap).
Message 17 of 20
(4,009 Views)
OK, guys. I get about 30% the matrix speed using the following hybrid approach, but when I enable parallelization on my dual Xeon with 16 hyperthreaded cores (i.e. 32 virtual cores), it is about 5x faster (~6-7ms for Bobs benchmark), i.e. a 15x speedup overall due to parallelization for that code fragment. (I have not tried the hi perf libraries yet.)
Message 18 of 20
(3,997 Views)
Altenbach catches my carelessness, again!  When I originally tested the Matrix method, I had the Absolute Value function in there, but when I went to make the code "pretty" so I could post it here, I forgot it!  Dang.  My guess is it will have a minimal effect on the timing (but, still, My Bad ...).
Message 19 of 20
(3,979 Views)
I would like to thank everyone for your prompt feedback. It has been extremely useful.
The fastest way to do it (at least on my PC) was to do a simple matrix multiplication (thanks Bob_Schor) together with the use of the High Performance toolkit (thanks mcduff).
Adrian
Message 20 of 20
(3,849 Views)
