optimization code memory
hello,
Any suggestion or idea to optimize this portion of code
thanks
(4,007 Views)
What is it even trying to do?
(3,996 Views)
hello Crossrulz,
Sampling a signal (20ms)
thanks
(3,987 Views)
What are you trying to optimize for?
Speed?
Memory footprint?
Low jitter in RT?
Readability?
Some other thing?
Since there don't seem to be any controls or inputs this will always generate exactly the same thing. Perhaps you could run it once and pass the output to wherever you need it.
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
Now also available on VIPM
(3,907 Views)
I use this code in RT. the memory increase if the signal is big.
  - 60s ==> table of 3000points.
  -10 min ==>  table of 30000 points
(3,867 Views)
With a predefined array size shouldn't change if you're using Replace Array Subset. If you're using Insert Into Array it's quite logical that 10 mins results in 10x the size of 1 min ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,854 Views)
Accepted by topic author RchB
my colleague propose me this and i fixe array size
(3,845 Views)
